In an effort to sort out the wealth of knowledge that we have in our hundreds of YouTube videos (and some gems from other channels) I am creating a list of them and categorizing them into groups to help you along your purchasing/learning journey.
Check out these videos when you are new to PathPilot and need a starting point.
Basics
Your First Day with Tormach’s PathPilot
xsTECH Basics, Setup for the Classroom - Part 1
Getting Started with Tool Tables in PathPilot
Getting Started with Work Offsets in PathPilot
PathPilot Quick Tips | How Do You Enable Tool Tips
Running an operation
PathPilot Quick Tips: Creeping Up on a Part
PathPilot Quick Tips | Feed Override
PathPilot Quick Tips: Tweaking Your Work Offsets
PathPilot Quick Tips: Typing in the DRO
PathPilot Quick Tips: Math in the DROs
Probing Routines in PathPilot - YouTube
Adding Tools to Your Tormach ATC with PathPilot
PathPilot Quick Tip | G Code Path Simulation
Conversational
Conversational Programming in Tormach’s PathPilot
How to Cut Holes with CNC | Tormach
PathPilot Quick Tips: Threading Multiple Holes with Conversational
PathPilot Quick Tips: Drilling with Conversational
PathPilot Quick Tips: Conversational Drill and Tap
PathPilot Quick Tips: Conversational Thread Milling
Tormach Quick Tip - Inputting Imperial or Metric into PathPilot
8 DXF Milling: PathPilot Conversational
PathPilot Quick Tips: Adding Serial Numbers with Conversational
Making a Pen with Lathe Conversational Profiling
Cutting Stainless Steel with PathPilot’s Conversational Profiling
I will continue to update this list as I find more helpful videos and I encourage you to post in the comments with other videos that helped you on your CNC journey.
In the mean time, check out the other video lists in this series:
- Chapter 1 - Getting Started with PathPilot: Here is a list of videos that will help you get started in PathPilot
- Chapter 2 - Getting Comfortable with PathPilot : These videos expand on some of what you learned in Chapter 1 and give you a more detailed look at the options in PathPilot.
- Chapter 3 - Getting Frisky with PathPilot: These videos highlight more advanced options that you don’ t need to know but can help you be more productive.
