Za6 robot frames and joints
Hi!
I have added an end effector to my za6. I am also using a custom ROS based vision system on another computer that is network connected to the za6 to publish tfs of interest to which I wish to move my new end effector. Since so much of our code was already in ROS, I am trying to send goals directly to the move_group node without going through the interpreter node or the robot_ui.
I was hoping for some clarifications about the za6 setup before I break something or waste a lot of time digging or going down dead end paths.
Looking at the za6 tf tree and the urdf, I see the flange attached to link_6, and that makes sense to me as to why it is there, but I am wondering about the other three frames I see: tool0, tcp_lin_link, and tool0_tcp and also the prismatic joints connecting them (tcp_lin, and tcp_rot). What are the purposes of these frames and the prismatic joints?
My guess is that the prismatic joints and the tcp links (probably standing for tool center point?) are somehow used in your wizard to determine new user tool frames and that I don’t really need to worry about them?
Also, when I add a new tool frame in pathpilot, it is a child of the tool0 frame rather than a child of the flange frame as I would have expected. I have found that I cannot specify my new link as a frame in a constraint because it is not actually a link. Looking at the goals that the interpreter node sends, you don’t use my created tool frame either, and just send tool0, so I am guessing that either the interpreter node does the offset to go from my tool frame to tool0 before sending the move_group goal or that it is unnecessary because of one of the move_group services that I can’t echo handles everything to go from my tool frame to tool0 and renders my tool frame unnecessary in the goal.
Am I doing something wrong with my frame setup through pathpilot or perhaps is there a way to add a real link with pathpilot? I see the other model types when I add a frame, so maybe that is what I should do, but I don’t see a way to add another model other than the ones you provide.
If I’m not doing anything wrong, then based on some of the other machines I’ve worked with, I think that the ROS way to do this would probably be to run the moveit setup wizard in order to add a new link with my end effector actually being a part of the arm. But if I do need to run the setup wizard, I want to make only necessary or minimal changes so as not to break anything, so I wanted to know the purpose of tool0 before doing it.
Thank you!
Hello @tbh
Sorry for the delayed reply. There are a couple of questions in that post, and I’m going to try my best to answer them:
  1. Your statement is correct, our tool wizard walks users through creating a tool_frame and auto populates those fields. We do not recommend users try to create custom values for tool_frame data points.
  2. PathPilot uses a user_frames to set waypoints, and when programing a move, you simply select the order of waypoints you want the robot to travel to. The way we have the software set up, tool_frames are not interpreted for these commands.
I don’t know if I quite understand what you are trying to set-up. I would recommend trusting PathPilot over a custom ROS, and I would be willing to work with you to get our product to fulfil the task you are looking to complete. If you submit a support ticket at Tormach Inc. - Jira Service Management and reference this forum post, I would be happy to review your set-up one-on-one and help get the ZA6 working for you.
Thanks!
@tbh
The upcoming PathPilot Robot release is going to enable remote ROS messages and setting custom ROS_MASTER_URI. This way, your robot can be a ROS master, and your computer vision computer can find it in ROS network and send it our custom ros service requests or publish to topics used by the robot.
A basic use of the upcoming functionality shown in the terminal of your computer vision system:
rosservice call /robot_command/execute_mdi "command: 'movej(p[0,0,0,0,0,0])'"
This would be equivalent to TRPL movej(p[0,0,0,0,0,0]) executed with the currently active tool and user frames.
Using the same service call you could apply other commands available in TRPL:
rosservice call /robot_command/execute_mdi "command: 'change_tool_frame(<frame_name>)'"
To use these custom services, you need to have our custom srv and msg definitions that are already available in: GitHub - tormach/tormach_za_msgs: Tormach ZA robot ROS interface message packages
Another, but much more complicated option will be to use our custom MoveIt stack, but that would require you to create a few new move_groups and include all the used tool frames in the URDF before launching the system (inability to change effector frames dynamically is a known limitation of MoveIt1). You would also be required to use our fork of MoveIt.
I will post here information about the relevant release updates. Thank you for your patience.
@Jakub_Kaminski Has this updated PathPilot Robot release happened?
@futnuh
Yes, we recently released PathPilot 3.2.4 for our ZA6 which includes the remote ROS feature Jakub was referring to. You may download the update directly from your controller, or from our website at: Tormach PathPilot Updates
Thank you. Looks like I’m up to date here.
Just an update on what I have learned in case it helps anyone else:
tcp_lin and tcp_rot are discussed more here. Basically they are experimental features that I don’t need to worry about.
I ended up creating a xacro file for my gripper and adding it to the za6_macro.xacro file in an overlay workspace. I also added additional groups to my srdf. This way I can plan directly to the frames I desire, they are consistent with my gripper and are not children of tool0. So now I do not need to plan to tool0 every time.
