ROS Continuous Jogging API
Hi, Im a student who is working on a research project with the ZA6 6 DOF arm. I am attempting to implement force based feedback control using the joint torques published to the ‘/joint_states’ topic to get the current force on the end effector and continuous jogging for the movement (preferably in a set direction/at a set speed).
When I try use the command line ros interface to jog the robot, the Robot responds as follows:
  • publishing “{‘frame_name’:‘’,‘axis_names’:[‘x’,‘y’,‘z’,‘a’,‘b’,‘c’], ‘values’:[560,0,700,0,0,0]}” (or other viable position) to \jog\continuous\set_pose resulted in erratic movement
  • publishing “{‘frame_name’:‘’,‘axis_names’:[‘x’,‘y’,‘z’,‘a’,‘b’,‘c’], ‘values’:[560,0,700,0,0,0]}” (or other viable position) to \jog\absolute\set_pose resulted in no movement
  • publishing “{‘joint-names’:[‘joint_1’,‘joint_2’,‘joint_3’,‘joint_4’,‘joint_5’,‘joint_6’], ‘values’:0,0,0,0,10,0]}” (or other viable pose) to either \jog\absolute\joint_pose or \jog\continuous\joint_pose resulted in the joints moving at full speed in the direction of the sign of the number, but they dont stop when they reached the correct position.
Note: units are set to mm/deg/sec, “{‘execute’:True}” is published to the /jog/execute topic a 10 hz in a separate terminal for the duration of the move for all of the previous commands, and everything is run from the ros-dist-ui docker.
If anyone has any advice on how to get continuous jogging working through ros your help would be appreciated.
@Joe_College Did you manage to sort this out?
I found a workaround, which is to use the “/position_trajectory_controller/command” topic. This is a joint space trajectory planner, which is not ideal, but it has a low enough latency that it can at least be used for real time control. The down side is that I have to do my own inverse kinematics and provide position and a move time (which can be used to achieve a specific velocity). Ideally, I would be able to just provide velocities, in either joint space or cartesian space.
