Robot Camera Man
I wanted to test out using the Za6 to hold a camera to film while I worked on different projects throughout my shop. I wanted to be able to send the robot to frame specific areas that I would be working quickly and predictably. I wanted a project that would allow me to also work with the I/O of the robot with simply hardware.
I made a button box from 4 arcade switches and an 8 conductor cable. I also added terminal blocks to the side of the robot cabinet to make it easier to interface with the I/O terminals quickly.
I also made a 3D printed camera mount to mount a DJI Osmo Pocket camera onto the robot using. This made a quick easy to use gimbal that I can control remotely and set to do object tracking or a forced position look. The gimbal makes all the robot movement ultra smooth. I purposely made the face plate mount weak so that if I crashed the camera it would hopefully fail before breaking the camera.
For programming it is a simple set of if/elif statements looking for button presses or combinations to tell the robot what pose to go to.
I did not add the camera to the collision model so I manually had to check the position combinations to make sure it would not collide.
Picture of the camera mounted on the robot.
Joe,
Can you post the stls for the camera mount that you printed? I’ve got a DJI Pocket II and I’d love to do some similar work with my robot. Thanks!
https://drive.google.com/drive/folders/1UNUXLwNryHFuBXwf3hmz_FTkfUfxmb4l?usp=sharing
That is the mount that I made to adapt a tripod mount to the robot.
Im using that mount with a standard go-pro tripod mount to adapt the osmo to the robot. It works really well and makes many camera angles and POV’s possible.
