I whipped up this example program in advance of a webinar I’m giving on Friday this week on using Python inside robot programs. I see a number of possible uses for having the robot take photos and store them on the file system. This example is really simple and is only meant to give people a jumping off point.
One my first run through of this program the camera was not working (which I had not verified ahead of time) and PP gave me an error that was tricky to understand.
Error executing program: File “Webcam_Rogge.py”, line 30:
OpenCV(4.2.0) …/modules/imgcodecs/src/loadsave.cpp:715: error: (-215:Assertion failed) !_img.empty() in function ‘imwrite’
This could be addressed by checking for the presence of a camera before trying to take a picture and save it or otherwise giving a human readable error message something to the effect of “Camera not found”
@Davie - welcome to the Tormach user forums!
Thanks for the feedback on that example program. I completely agree - a check to ensure there’s a camera connected and functioning would save the next person who tries this code out a lot of hassle. I’ll make that code change and push it up to the repository ASAP. Thank you!
The aforementioned exception is propagated from the underlying C++ OpenCV code. You can catch them as you would usually do in Python, for example
while (result):
try:
ret, frame = videoCaptureObject.read()
cv2.imwrite(filename, frame)
result = False
except Exception as e:
notify(f"Exception: {e}", error=True)
(Not exactly useful, but you get the gist. The action and meaning of the exception will be always on the programmer.)
You can actually check the camera connection after creation of the VideoCaptureObject with the isOpened method. Pull request at Check the camera is connected by cerna · Pull Request #2 · tormach/example_robot_programs · GitHub does exactly that.
@sorgule Replying to myself- I’m not sure how “scientific” this is, but I turned off the machine and turned it back on and the problem fixed itself.
@sorgule I’m glad it’s now working for you. If the problem happens again or you find a way to reproduce it please let me know.
@sorgule and @Davie - We found a quirk the other day with this program. Some cameras return a ‘blank’ frame when the camera object is first opened. An easy workaround is just to throw out the first frame returned and use the second one. I updated the example code on GitHub to reflect this. If you run into the problem yourselves, this code snippet would help you past the problem:
while (result):
# throw away first frame because some cameras return a 'blank' frame for the first read
