Just curious if anyone has setup an Xkeys Jog/Shuttle with Path Pilot? Might be neat to setup the keys on the device to do common GCode commands also.
I am also look for key caps for mechanical keyboard switches that are for Path Pilot common functions.
Instead of PGUP PGDOWN have Z + and Z-? THat kind of thing.
THe XKeys device i have used there stuff for video prodution. You can change the lights on the keys so you know what button is active. Like if you are in Z axis mode and using the Jog/Shuttle to go + or - you can turn the Z key red or blue to indicate are are moving the Z axis.
I would just need to figure out what keyboard commands path pilot needs to setup the programming.
