Create a New User Frame
Select Add Frame to create a new user frame. In the window that displays, you can name the new frame.
Note: Creating a new frame doesn’t automatically apply that frame. You must either select the frame in the User Frame drop-down menu on the “Position Status Readout” group of the persistent controls, or use the change_user_frame() command in a robot program.
To teach a new user frame’s XYZABC offset values, use the Update Frame Using Wizard button.
