Hi Tormach Forum!
I’ve been banging my head against this for nearly a week. Isn’t P (dwell) part of G73?
Could someone give me a hint as to why PathPilot doesn’t like the dwell code in this line?:
I’ve tried changing P to 1, 1. and 4.2 without luck.
When I load my file in PathPilot, the screen instantly switches to the status screen with this message:
G-Code error: P word with no G2 G3 G4 G10 G5 G5.2 G38.X G54.1 G64 G76 G82 G86 G88 G89 or M50 M51 M52 M53 M62 M63 M64 M65 M66 M98
I noticed G73 isn’t listed. Shouldn’t it be?
BobCAD gave me 4 different post processor files to try, and they are each a different color dumpster fire.
I changed this to a chip clearing peck G83, but BobCAD still adds the P word. At least PathPilot just warns about it, ignores it, and runs the program.
OK. Thanks Sam. I really thought I saw somewhere that P was an option for fast peck.
This is a post processor issue then. BobCAD keeps putting P words in on G73.
It does work when I remove the P word.
So if I wanted peck AND dwell it should be a G83. I just need to sort out how to make BobCAD choose G83 instead of using G73 with P.
G82 and G84 have P. Oddly enough I don’t recall ever seeing G73 in milling/drilling. I thought it was a turning G-code. A repeated cycle IIRC. Used for roughing a profile the P and Q are the repeat lines. this is followed by a G70 as a finish cut. which refers to the P and Q of the G73. LOL…Then again, Its been more than 10 min since I’ve programmed like that. Interesting though. I’m gonna have to look into it.
