The tailstock on my 8L seems to be a little bit off on the X Axis. How do I adjust it back to center ?
I see a couple of set screws on the Tail Stock, which one should I use to adjust on the X-Axis.
Sandeep
Sandeep
Sandeep,
You use a combination of both screws to do the adjustment. If both screws are cracked loose, tightening on a specific side, will shift the tailstock to that direction.
Hi Sam,
Thanks for the response, there is a set screw at the back of the tail stock , does this need to be loosened for this adjustment ?
Sandeep
Thank you Sam,
That worked; all aligned now.
Sandeep
Yeah, mine was off by several thousands also…brand new machine, first tailstock use. Whoever is doing the QC reports on these things are fudging the numbers a bit … …at least on the tailstocks.
