Is there a way to turn off an already milled layer on the screen in PathPilot.
When milling out a pocket I prefer to drill out first. The mill will spriral mill in each layer due to no way to indicate predrilling.
I would like to be able to pick a start point at each layer to avoid spiralling in.
The red path obscures the next layer. If this could be blanked out it would be easy to pick the next start point on the screen.
Dave
If you double click on the preview window it will clear the red lines
Seriously?!? How did I not know this earlier? I gotta try this out for myself.
Having learned a new thing today, I would still ask if there is any plan to add an option or otherwise change the behavior or the preview graphics to only show the current operation. I know about the option to only show current tool and that’s helpful but for large programs with a lot of adaptive/dynamic toolpath roughing, having all that mess automagically cleared from the screen when the next op starts would be great.
thanks, did not know about that. I will see if I can find the level I want this way.
Dave
Also, the tab next door? You can turn off individual tools.
It does make it easier but still wish the whole level would be blanked out.
Dave
