Here is easy way to organize your XS tech router bits.
This is built on standard Select Pine that can be found at any hardware store. The Select Pine comes dimensioned at .75in X 3.5in X 6ft long. This piece is precut to 7in long.
The G-code files are:
Milling Square pockets for tool holders
Roughing pass- Bit 39163
Roughing G-code: Pocket tool holder.nc (212.4 KB)
Finishing Pass - Bit 39167
Finishing G-code Finishing Tool holder 2.nc (72.6 KB)
Number Engraving - Bit 39165
Engraving G-code engraving - #.nc (16.4 KB)
X0 Y0 Z0 are referenced at the Top Left of the stock with the Z stablished on the top of stock. The stock is set to dimensions, so G-code is only designed to mill out the pockets and engrave the numbers.
