Hi everyone,
I’m having an issue with my Tormach PCNC 440 running PathPilot, and I’m hoping someone can help. I was in the middle of testing a program that had been running fine until it hit a tool change. Instead of moving to the tool change position, the machine just stopped right above the part. I tried stepping through the commands, but it never moved to the tool change position in the Z-axis, and I didn’t get the usual blue bar across the screen prompting for a tool change.
To troubleshoot:
• I loaded a previously proven program that ran fine before, and even that one is failing to execute the tool change.
• I verified that the M6 commands are present in the G-code and confirmed my Tool Change Mode settings in PathPilot are correct.
• I checked the G30 position settings, and they seem fine.
• I recently updated PathPilot, and the issue started around that time. I rolled back to the previous version I had, but the problem persists.
Additional context:
This all started when I was installing an ATC. It was giving me some issues which I’m working through with Tormach’s tech support, so I decided to disable the ATC in the settings and go back to manual tool change mode. However, I left all the connections from the ATC in place, so I’m not sure if that’s contributing. The ATC install is what prompted the software update.
Has anyone experienced something similar or have suggestions on what else I could check? Any help would be appreciated!
Thanks,
Edgar
