I just finished getting my 440 up and running. I need to purchase a precision machinist level, a stone, shim kit, block, etc. I don’t see a stone or level listed for purchase on the website, even with a lot of searching.
Q - Do I need to find a good tooling supply website?
Q - Anyone willing to suggest a $250 level?
No need to by new… any precision Starrett or similar in ebay in good condition will work great… they are easy to re- calibrate… for a stone are you referring to a surface plate?
Are you expecting to use the stone on the machine table or the parts that come off it? Either way it’s something I wouldn’t bother buying until you actually need it. They’re only $25 or so though so can be thrown onto another order from a tooling place.
I like the idea of an old eBay Starrett level, but precision level technology is not complicated and any random import level that is accurate enough will do on a 440 (levels tend to come in order-of-magnitude ranges, like ~.02"/ft for carpentry ~.002"/ft “machinist” and ~.0002"/ft “precision”).
HAAS tooling has a suitable precision level for $100 or so as does LittleMachineShop and Shars and probably a lot of others. Always flip them end to end and recheck in any case.
Level was whatever you can get off Amazon/eBay for ~$50-60 unless you are already planning to buy a machine an order of magnitude more precise than the 440.
I’ve had good luck with using carbide off Amazon on a 440 given it can’t use anywhere near the max feeds/speeds of larger diameter carbide. It can be ~50% of what you pay for premium carbide. Don’t know if you are learning (and anticipate breaking carbide) then you probably may want to hold off spending $$$ on premium carbide for a while.
The ones Davie uses do not appear to be precision ground… fwiw I use mine nearly daily on vise jaw faces, parallels or any number of other surfaces … if you have never heard of these do some research… they work completely differently than a sharpening stone
heres a video from Rob Renzetti who helped popularize them
I’ve seen a lot of factory new machine setup guys using about the same stone Davie uses for putting million-dollar machines into service. Always amusing the final setup is so often careful tapping with deadblow hammers and measuring with indicators.
Ive been a tool maker and injection mold maker. I use these stones almost daily and they have been excellent. Remember to ALWAYS use lubricant when using stones to keep them from clogging.
This is my favorite for fine details, this stone by DansWhetstone (Black Arkansas Ultra Fine (3" x 1" x 1/8" )) will not show scratches on surfaces because its so fine: Pocket Stones - Dan's Whetstone
