Spindle plunged toward vise uncontrollably
I went to use my CNC machine – PCNC1100 S3-- and powered everything on as I always have. Everything seemed good. I told the tool changer to store the tool, it did that no problem.
I jogged the table over a bit (X-axis) so that I could open up the vise. After that, I did not touch the controller or tell the machine to do anything, it was perfectly still and everything was normal.
I walked away to grab my stock, brought it back, and then went to grab a tool to open up the jaws of the vise. By this time, about 1-2 minutes had passed without me touching the computer or telling the machine to do anything. However, as soon as I turned my back to grab the tool, I heard the machine start making a clunking, clicky, grinding sound as the spindle started falling toward the vise.
I went to the computer and tried to hit ‘STOP’ on the commands, but the spindle kept falling and making that clunky sound. I had to E-Stop it before the spindle almost hit the vise.
The machine didn’t make the usual whirring sound, as though I had told it to go to a certain Z-level. It just started dropping with that clunky sound, like gears were being forced, so I don’t think it thought I had commanded it to do that.
It seems like the Z-axis brake failed, whether that be because it needs to be replaced or the computer malfunctioned and told the brake to disengage, and gravity pulled the spindle down.
When we turned the machine back on, the spindle did not move or start falling again, but it has not been commanded to do anything since the incident.
I might suspect the z axis stepper. To my knowledge, the z axis brake engages whenever it’s not powered (machine off, e-stop activated, or machine in reset). Once the machine is powered, e-stop off, and out of reset, the brake should be released and the spindle is held in place by the stepper.
If the stepper is failing, or if the wires to the stepper are loose or damaged, it’s possible the stepper stopped providing holding force, or wasn’t providing enough holding force, to keep the spindle from dropping. Activating the e-stop dropped power to the brake, causing it to engage and stop the fall.
My suggestion would be to check the wiring to the stepper to make sure the connections are all good and there is no damage to the wiring or conduit. If that checks out, I’d probably swap one of the other axis steppers to the z and see if the problem repeats. If not, your z stepper is likely on it’s way out and needs to be replaced.
