In File Dialog:
- Copy & Load button. One click to do both.
- Remember the last folder I was when I reboot machine.
Probing:
- Rectangle Probing without doing the whole perimeter dance. Ask for rough measurements of the rectangle stock and have the probe do its thing on 4 sides only. Say we have a 100x100mm stock… Enter the size in a dialog, jog the probe roughly to the center on the top, and ask how much to lower Z to probe the outside of the rect. And GO… Do some over travels and then probe + or - accordingly to get the center of the rect!
- Protected Move. If the probe triggers by any means when not expecting it… STOP all movement to protect the probe for damage. Not only show a message… STOP the machine.
Extra Points: Router Comp… Use the probe to probe a mesh on the table and adjust Z high accordingly for defects in the flatness of the table. Good for engravings and fine details that would not suffice with a sacrificial MDF… And PCBs on the smaller router. (Not my case)
Error Messages:
- Have the error messages appear momentarily in the screen I am without having to go to the status page.
- Show error messages in the units the machine is configured to. If in MM show the errors (Rapid will excede X axis by NN) in the units that are set.
Convenience for MCode USB accessory owners needing coolant:
- Have a setting to Reroute the Coolant button / MCode → to the USB accessory MCode gadget so that owners of Routers can use coolant using the USB box/relay when we don’t have a flood coolant or other coolant interface as the other CNC machines. (This will give us the button in the main screen to turn on/off and also avoid editing the post processor to fix this).
Hope this helps!
Keep up the great work!
Any idea when the next version will be released?
