I have a Series 3 PCNC 1100.
I have SmartCool with MultiCoolant Module to control both Flood coolant and a Fogbuster. I have not installed the Fogbuster yet and would like to know if there is any other products I need to buy to make Pathpilot switch between the Fogbuster and the Flood coolant using M-Codes?
Do I need the USB I/O module for this?
Bill
Bill,
You don’t need the USB IO module, the smartcool handles switching between the two.
Thanks Norman. I appreciate the clarification.
I assumed I should run mist for the Fogbuster, but it uses the flood command from Fusion360, same as the SmartCool.
The standard Tormach post for Fusion may not support multi-cool. I use David Loomes post and it handles flood v mist very well. You have to make sure your post configuration is set to smart cool AND multi-cool is selected or the mist function wont work.
