I have a Tormach 440 mill, and I am having a heck of a time figuring out how to setup the path pilot component.
I have the new version of the path pilot, and I am honestly not sure how it directly connects. I have not found any upgraded documentation which shows how this works, although I am certain that I am over thinking it. Do I connect the RG-25 port on the wiring cabinet directly to one of the com ports of the controller? Or does it connect through blue tooth?
Why is there an RG-25 port of the periphery controller?
The 440 originally came with a “full size” PC that had a PCI card with that 25-pin machine interface port which connects to the Leadshine stepper controllers for the axes, limit switches, and BLDC drive. The 25-pin interface on the back of the 440 hasn’t been updated but PCs have changed dramatically since the release of the 440.
That new mini PC can’t accommodate that piece of PC hardware, so you have the intermediary device Davie specifies which converts to an Ethernet port.
This was pretty much a guess for me, not clear. Most likely the documentation on the device between the PathPilot controller DB25 and the Leadshine is updated by now?
