Runout measurement after mild crash 1100MX
Hello folks. Last week I had a little crash and wanted to check out the run out on my spindle. I do see ±1um which I assume is good. Let me know if I’m not measuring this right. I’m placing the dial against the inner wall of the spindle such that the movement of the dial probe is perpendicular to the BT30 inner wall. That way I figured I’d increase my sensitivity. I’ll also try to put the dial against the outer wall of the spindle and compare, but based on what I see, the spindle should be okay and I don’t hear anything weird from the bearings.
IMG_5142
Hi, I think ±1 µm sounds very good, assuming the indicator and setup are accurate. I’d also check the taper with a clean test bar and compare readings at different positions. Checking the outer surface can help too, but the test bar should give you a better idea of the overall spindle condition after the crash.
Looks good from spec.
Went through similar to check my 440. There are two figures and more play further away from the spindle nose is allowed.
The video is fun to watch, but you are running the spindle far too quickly to accurately measure the runout. At that speed, you are floating the indicator, which prevents an accurate measurement.
You should just be rotating the spindle by hand to check runout.
Mild crash as in broke an end mill or tool holder bumped vise or something? Remember, speed kills. Force equals mass times acceleration. :slight_smile:
