Repositioning the 770MX-North Atlanta GA
I need to fabricate a mechanism that I can attach to the base of the 770MX so it can be moved out from the wall for maintenance and also moved into a VERY narrow hallway. I would like to touch, feel, measure the sheet metal base of a 770MX before I buy two units.
Does anyone in the North Atlanta Georgia area have a 770MX that would allow me to come take a look at the machine?
You can reach me at brobinson@cmi2.org or 404-245-9123. Thanks.
You should be able to put a pallet jack under it no problem. That’s about as easy as it gets. If the floor is really flat you could try an air cushion mover under it. Those things make moving a tank easy.
