I adjusted my power draw bar bolt to the tormach spec of .25 in with no tool in the spindle and started to get the “reorient from trayin” error message.
I had seen a great youtube video by Jayson at VC Edge on this topic the week before but had no use for the information so I didn’t fully retain it. I was talking to support about something else and it came up. They recommend modifying the bolt head so there is a much smaller contact area when the bolt strikes the draw bar.
I won’t bore you with the details here but if you’re interested go look at Jayson’s video here https://youtu.be/eiMv287-EvU?si=JxQZqQRrKjM_SYPy
Here are a couple pictures of mine modded on the lathe. I just put a 10 degree chamfer on it which so far seems very sufficient. Jayson’s fix is much more sophisticated and more interesting.
