Hello there! Running a plasma cutter but when its cutting It eventually runs into the metal. Attempted a dry run to make sure that motor is holding the head correctly. It is.
@Ryan_Maicus Check out this knowledge base article on this issue: https://tormach.atlassian.net/wiki/spaces/KBP/pages/3328770114/Plasma+Torch+is+Diving+into+Material
That solved our issue @SamBollen . Appreciate you sending that I had a feeling there was a forum but couldn’t find it. Ill be working on the plasma to make sure its all good later.
