Hello Tormach Forum. This is my first post.
I have a PCNC 1100 Series 3 running PathPilot. Last night, while checking tram and level, the mill suddenly lost power, although the PC stayed on. I had stepped on the power cord right when it happened, so I’m not sure whether that was coincidence or if there was an issue with the plug itself.
After shutting down the PC/controller, I unplugged the machine and tightened all terminal/wire connections inside the plug. Nothing looked obviously wrong, but the strain relief was loose, so I corrected that by wrapping an additional layer of insulation around the cable to tighten it up.
Next, I removed the access cover for the Z-axis ballscrew/coupler area at the top. I used channel-lock pliers with heat shrink tubing on the jaws to avoid damaging the coupler and manually moved the Z-axis to a safe position by turning the coupler with the pliers.
After reconnecting power and booting the control PC, I powered up the machine. Immediately, the Z-axis started moving downward toward the table and made a new growling/grinding-type noise. I still had the tram tool installed, and it looked like a crash was imminent, so I hit the E-stop.
I rebooted the system and tried again. Same behavior. This time I kept my hand on the E-stop because the Z-axis was already very close to the table.
I used the pliers again to manually move the Z-axis back to a safe position, then disconnected power completely and called it a night.
Today, I tried again and the exact same thing happened: as soon as the machine powers up, the Z-axis immediately starts driving downward with the same growling noise.
I’ve checked the visible connections and don’t see anything obvious. Since Tormach is closed today (Saturday), I’ll open a support ticket when they reopen, but I was hoping someone here might recognize this issue. Is this a known problem that can be reset/recovered from, or does this sound more like a hardware failure (something in the panel)?
I was hoping to finish the tram work and get the machine running again over the Memorial Day weekend, but this definitely threw a wrench into things. Seems like something needs to be reset or a hardware failure to me and not something simple like a stuck pendant or keyboard button, etc.
Any insight would be greatly appreciated.
