PCNC 440 Remove Spindle Block
How do I manually move the Z axis up before powering up the PCNC 440 so I can take the spindle block out? I don’t see this referenced in the instructions.
@Daniel_Cook welcome to the Tormach Forums!
You will need to power up the machine to remove this block. I will pass this note along to the technical writing team.
@Daniel_Cook Could you by chance tell me what version of the manual you are looking at? I just checked the online (most current) version of the manual, and it looks like the order is correct. The current version of the manual is Version 1124A.
the manual that was supplied with the machine has the number UM10372_PCNC440_Manual_0224A
You can pull the latest up to date manuals here: Tormach PCNC 440 Documents
The printed manuals can lag behind.
