Any one install this yet. I haven’t had time for the shop for a while, I’d like to hear it was successful before I bother.
Dave
Dave
Installed it the same day.
No issues noted.
Edit
Turret tool selection in the lathe like Andrew stated.
Reverted back to V2.10.1, works normally.
thanks. I hope to have time tomorrow
Dave
Using the 4th axis, round stock, on the 770MX, I milled flats, square pockets, drilled holes in the flats and circumference. I was having trouble with a cam lobe shape. Friend is checking the G code for oddities.
Reverted back to V2.10.1 and problem is still there, so back to V2.12.1 on the mill and V2.10.1 on the 15L.
Just getting into 4th axis stuff.
If you don’t use the machine after an update, you won’t know of any issues. Updated the lathe but was unaware of the old turret not changing tools issue.
Tormach will sort it out.
Has anyone else noticed the floaty jogging when using the keyboard? I will try another keyboard just to be sure it’s not me.
Is that since updating to 2.12?
Once you’ve tried another keyboard, and if you still have an issue. I think we sould grab a video and create a ticket with the Tech team. This sounds a little odd.
Updated 770MX PathPilot to 2.12.1 & numbers are yellow. Is this a new feature or a warning of an issue?
Tom
We made different types of variables a few different colors on the G-code preview window to help visually break up the commands and make the program easier for users to read.
The yellow numbers I saw are the x,y,z position and others on the main control page for all the functions.
I wonder if this is the same issue…
For a few minutes after the 1100mx is turned on, jogging via the handheld jog pendant is erratic. All 3 axis have the same issue. Rotating the knob in either direction on any of the 3 axis results in movement that is not smooth.
After a few minutes this problem goes away.
Check for lubrication, might be a little sticky.
Went back to PathPilot 2.10.1 and the jogging problem went away. I have a ticket open for DXF problems with 2.12.1. I also posted the DXF problem in the mill forum.
