PathPilot Hub and testing g-code
I put together my first project in Fusion 360 and uploaded it to pathpilot hub for milling in my 770m. I received so many g-code errors about exceeding the x and y axis. I had some probing sequences set up, but how do you probe a non–existent stock in the hub? How do you get it to know exactly where to cut? I’m feeling a bit lost with this and can’t find a youtube video to get me back on track. I’d like to know if what I’m doing is correct before I put it in the machine.
You can’t probe on the hub environment so you have to manually set your wco. Just jog the machine out in the middle, activate the proper wco, zero all of the axes. Then you can run the code to check the rest of it
That makes perfect sense. Thanks!
