Oiler does not return to original position, also leak
It is VERY important to note that this machine has been sitting unused for 2 years, and this I am also using this machine for the first time, but ive had some experience with haas machines.
The oiler leaks where the towels are, and when the handle is pulled, it does not return to its original position unless I physically push it back (it is also not the easiest thing to push).
How should I proceed from here?
Given the other posts about this 440, it’s not what you want to hear, but pull all the covers you need to and inspect the outlets for those lines to make sure you are actually getting way lubricant at the end of each line and that all three axes are actually being lubricated. It’s possible something was monkeyed with or is blocked. You don’t want to assume that fixing the leaks you see guarantees it’s reaching the intended end point.
I should say mine behaved similarly (leaks) and I think had similar handle behavior, which is why I suggest exposing everything…because that’s what I did to make sure it was all good…
What’s leaking? Is the hose broken or the fitting leaking?
I was working on my buddy’s 440 recently and found line at the auto part store that fit. Tormach also sells the stuff if you want OEM.
If you take the lid off the oiler does the handle retract? To Ashrafs point, if your oil lines are blocked then the handle will get going. If the oiler is gunky then the handle could be sticking.
If it’s been siting for 2 years the oil jets are probably completely clogged and that is why the oil is coming out the fitting and the plunger isn’t returning.
