Hey all, Anyone using the Micro Arc Homing Sensor? If so have you permanently mounted it to the MA? Seems so thoughtless that there is not an off-the-shelf mounting solution to permanently locate and mount it to the 4th axis. Maybe I just don’t understand the use of it yet, IS it even necessary to permanently mount it, make sense to me, any comments welcome. Ive not used the 4th axis yet so not sure on the function of the it. For the current part set up Im going to be using it to index 5 sides of a part and the rotation angles need to be dead on to the part. Ive downloaded futnuh chip guard and thinking about integrating the sensor into his part. Thanks to futnuh for sharing the file. IF I do this I will post it here for others to use.
I don’t think it’s necessary. The only time you would use the homing sensor is if you rotated a part and then turned the machine off then back on and continued cutting the same part.
OK. Since I have not used the 4th axis yet I guess I don’t have a perspective on its function and CAM set up. So orienting the rotations on the machine and making sure it 0s out does not really even come into play I guess, then RIGHT? Since all rotations are being dictated by CAM, right?
Two scenarios.
Without sensor.
When you power on the machine and hit reference the A axis does not move. The work offset table for A is appended to the current value.
With the sensor
When you power on the machine and hit reference the A axis will spin until the hal sensor triggers and the work offset table will not be appended.
I would say that there is no way that the sensor is accurate enough to reference within 26 arc seconds which is the resolution of the MicroArc. I say this because to resolve to this resolution the sensor would have to resolve 1/138 of a degree which is possible but prohibitively expensive in this scale.
If you are using the A axis you are better off finishing the program or typing A0 before shutting down.
Or couldn’t you add A0 to your program right before the M30?
The Santa clause I have been making use a spiral pass and at the end of the program A = -860,000.
There must be a way to get the A-variable and then run some math [ A/(Mod=360) -A ~> ] to reset the A axis to whatever degree of 360 it is at and then G0 A0 instead of unwinding, because that’s almost 3,000 revolutions. I don’t knownhow to get axis variables but someone here could probably knock together a quick couple lines to perform the function and post it up.
Maybe.
Posting without comment:
+ writeBlock("");
+ writeComment("Force rewrap the rotary axis routine");
+ writeBlock("O4269 SUB");
+ writeBlock("O42691 IF [#<_A> GE 0]");
+ writeBlock("#31 = [#<_A> - [FIX[#<_A>/360] * 360]]");
+ writeBlock("O42691 ELSE");
+ writeBlock("#31 = [#<_A> - [FUP[#<_A>/360] * 360]]");
+ writeBlock("O42691 ENDIF");
+ writeBlock("(DEBUG, A=#<_A> 31=#31)");
+ writeBlock("G92 A#31");
+ writeBlock("O4269 ENDSUB");
+ writeBlock("");
And then:
function onSectionEnd() {
+ writeBlock("O4269 CALL");
Probably a better way to do that, but this will reset the A axis without forcing it to unwind 3000 times.
(And now with more comment, since I have a moment…)
This takes the current A axis position (#<_A>) and calculates it mod 360 to figure out where it is. Mod doesn’t exist in PP, and rounding doesn’t round to 0, so we use a slightly frustrating if block to either truncate down (FIX) or truncate up (FUP). We then use G92 to take the resultant value and make the A axis be at that. So, for instance, if A was at 540, after this A would be at 180. Wouldn’t have turned at all but the next move to, say, 190 would just be a ten degree forward vs 350 backwards.
Need to use carefully, of course - it might be that you wanted 350 backwards! But I had the same issue that @Dr_Harold_Jones had and ended up with A=-860,000. After running this sub it’d be A=40 without having to unwind.
Awesome!
Exactly what I’m looking for. I’ve just stated using my MicroArc and of course almost immediately ran in the annoying unwind issue.
All figure out how to patch this in.
Does the XoomSpeed post handle a rotary 4th axis?
I guess I’ll find out - about to try it.
