Thanks for the help. Hopefully your first suggestion works; the article talks about displaying images via separate .jpg files which would be overkill for my needs (and extra work). I’ll do a test run this morning.
Well I’m glad this worked out for you! I don’t use the image display very often but it comes in very handy when I have a potential collision. If you want to use this feature then you just replace your comment with the image file name (must be .jpg or .png) and the image file needs to be in the same folder as the gcode. Here is an example of a stock prep operation where the toe clamp placement matters.
