Manual drawbar installation on the 440
Anyone have the instructions for a manual drawbar installation on the 440? I’m a ‘better safe than sorry’ type. I have spent 45 minutes looking. There are many power drawbar instructions all over the interweb but nothing for the drawbar.
Jim
It seems easy enough, but I may need torque setting, if it really needs anti-seize lube, is it one washer with a shelf, etc. Thank you!
And, is this really new or really old? https://docs.tormach.com/
I’m not sure what what that link is. I haven’t seen that before and will look into it tomorrow.
Check out this page for a lot of docs on the 440 including a PDB install doc
https://tormach.com/support/mill/pcnc-440-installation
Thank you Davie, maybe I wasn’t clear enough but I do not have a PDB. I have a DB (drawbar), I guess.
The DB (drawbar) is not installed on my 440 spindle. I was hoping to find instructions to be sure I have the correct torque, etc.
440 drawbar link
I found what I was looking for in the TD10408: Owner’s Guide: TTS CNC Operator’s Set. It is in the TD10416: Owner’s Guide: TTS Basic Tooling Set as well.
“Drawbar Tension The drawbar tension necessary to avoid tool pullout varies with the work. Experienced operators quickly gain a feel for the torque needed. The worst case is usually a large spiral fluted high helix end mill, running under heavy load and vibrating while cutting. Without a very tight drawbar tension, Tormach Tooling System (TTS) can pull out under those conditions. In that sort of instance, we recommend as much as 25 to 35 ft lbs of torque on the drawbar. Under standard operating conditions, most people will tighten about 12 to 20 ft lbs of torque.”
Something like this should be in the user manual and maybe the install guide.
