I just updated and have a bug already.
I was using the conversational drill for a circular pattern. It drilled the first hole then moved to the next one and didn’t drill, just kept moving to the next position in turn. I tried it with entering in a square pattern, Same issue, just drilled the first hold…
Reverted to the previous update and problem solved.
Any one else have this problem yet? Of course this shows up on a saturday.
Dave
WTF - does the same thing with .nc program - hope this is fixed asap - now have to figure out how to revert to previous build
Well it’s very easy to revert - had not needed to do that before
back to making $$ - I’m sure it’s something very simple to fix the bug
hopefully they get it done this coming week
This should be addressed in a hot fix the software team has coming. Reverting back was the best call, until the fix is released!
Hi all - PathPilot v2.12.1 is now released which includes a fix for this. Thank you for reporting!
