Turned on my 15L today, got this message. Powered off the machine now the controller won’t turn on.
Anyone know of a fix? Thanks!
Never seen an error like that before. Might be worth removing and resetting the RAM and any other peripheral cards in the controller. Sometimes they do vibrate a little loose and cause weird errors.
I doubt it has any bearing on the situation, but while you’re in there, it wouldn’t be a bad idea to replace the CMOS battery as I imagine it’s fairly old and will eventually cause you some other fun problems.
It’s a Gigabyte BIOS error so searching PC forums might turn something up. Never hurts to reset the BIOS settings, reseat any expansion boards / connectors and replace the CMOS battery if there is one.
Looks like the PC controller I have circa 2017 for my 440. Most likely the effects of the CMOS battery failure where the motherboard configuration was lost and needs to be reset. What date/time does it think it is? When you get back into BIOS, if isn’t today, that a strong indicator of what you are dealing with. When you open it up to swap the coin cell battery, you should see some LEDs to indicate if it’s getting power/status.
Update: I have reseated the ram, and changed the battery on the motherboard and am still getting the same error message.
Probably time to call Tormach and see if they’ve seen it.
