G code repeating
I have a Fusion generated G code file that runs on my 440. It works fine except it will not quit! I can find the lines in the code that call for the two processes (setups), bore and contour, but at the end of the contour instead of ending it repeats the bore but I can’t find where in the code it is repeating as nowhere is there a line noting a second bore process. It is like the repeat bore is integrated in the contour process somehow. Anyone able to advise?
M99 and variations therein will repeat a process. Keep an eye out for that. Otherwise you van use the single block button to step through your program line by line to see where the restart is happening
