Fusion 360 4th Axis Post Processor Help
Hello,
We have a Tormach 770M with the 6in manual tilting 4th axis. Finished up our design and tried to post. Getting errors,
Information: Configuration: Tormach PathPilot
Information: Vendor: Tormach
Information: Posting intermediate data to ‘C:\Users\17163\OneDrive\Documents\Fusion 360\NC Programs\1001.nc’
Error: Failed to post process. See below for details.
Code page changed to ‘1252 (ANSI - Latin I)’
Start time: Tuesday, January 21, 2025 7:36:41 PM
Code page changed to ‘20127 (US-ASCII)’
Post processor engine: 5.207.0
Configuration path: C:/Users/17163/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts/tormach.cps
Security level: 1000
Include paths: C:/Users/17163/AppData/Roaming/Autodesk/Fusion 360 CAM/Posts
Configuration modification date: Monday, January 13, 2025 8:55:02 PM
Output path: C:\Users\17163\OneDrive\Documents\Fusion 360\NC Programs\1001.nc
Checksum of intermediate NC data: 4e0da7e93ff32fc05d01f0dd72d88dfc
Checksum of configuration: 8fde8b6e051b436f8ae50e84a331d0a6
Vendor url: http://www.tormach.com
Legal: Copyright (C) 2012-2024 by Autodesk, Inc.
Generated by: Fusion CAM 2.0.20981
Error: Function ‘positionABC’ can only be used with multi-axis machine configurations.
Error at line: 2424
Error in operation: ‘FACE FROM Z1.2 TO Z0.6’
Failed while processing onSection() for record 401.
Error: Failed to invoke function ‘onSection’.
Error: Failed to invoke ‘onSection’ in the post configuration.
Error: Failed to execute configuration.
Stop time: Tuesday, January 21, 2025 7:36:41 PM
Post processing failed.
Any help would be greatly appreciated!
I think you need to tell Fusion you have a 4th axis in the machine definitions as it’s not enabled by default. It can also produce annoyingly obtuse error messages if you try to use ‘multi-axis’ toolpaths instead of 4th axis index/wrap/etc the way it expects.
In the post processor settings, there is a dropdown field for the rotary axis. You need to select which direction the rotary is pointing in (X+/X-/Y+/Y-/None). If that field is set to none, or left blank, you will get that error.
