Hi I suddenly an=m getting an Error on Posting a Gcode with the Fusion360 and the ARc4.
Even using older files that did work, I am now getting this error, and it wont write the Gcode.
Information: Configuration: Tormach PathPilot
Information: Vendor: Tormach
Information: Posting intermediate data to ‘Z:\2024 Files\PROJECTS MAKERSPACE\TORMACH ARC DEMO 4\GCODE-FAIL-.nc’
Information: Total number of warnings: 1
Error: Failed to post process. See below for details.
Code page changed to ‘1252 (ANSI - Latin I)’
Start time: Tuesday, August 6, 2024 3:58:18 PM
Code page changed to ‘20127 (US-ASCII)’
Post processor engine: 5.171.0
Configuration path: C:/Users/dgillard/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts/tormach.cps
Include paths: C:/Users/dgillard/AppData/Local/Autodesk/Autodesk Fusion 360/CAM/cache/posts
Configuration modification date: Tuesday, June 11, 2024 3:04:28 PM
Output path: Z:\2024 Files\PROJECTS MAKERSPACE\TORMACH ARC DEMO 4\GCODE-FAIL-.nc
Checksum of intermediate NC data: 211651059cc9407ad5d909597477d49f
Checksum of configuration: 02c0cdf28830799c88d5cfbc69b43776
Vendor url: http://www.tormach.com
Legal: Copyright (C) 2012-2024 by Autodesk, Inc.
Generated by: Fusion CAM 2.0.19941
Warning: The Work Coordinate System (WCS) Offset is set to 0, which defaults to using G54. It is likely that you do not need to change the offset because for most machines, the G54 WCS offset stores the location of the Setup’s origin in relation to the machine’s origin. To change the WCS offset, go to the Post Process tab of the Setup dialog, and enter 1 for G54, 2 for G55, and so on.
Error: This post configuration has not been customized for 5-axis simultaneous toolpath.
Error at line: 2049
Error in operation: ‘Rotary Pocket2’
Failed while processing onRapid5D() for record 407.
Error: Failed to execute configuration.
Stop time: Tuesday, August 6, 2024 3:58:18 PM
Post processing failed.
What is wrote…
(GCODE-FAIL-)
(T9 D=0.1875 CR=0. - flat end mill)
G90 G54 G64 G50 G17 G40 G80 G94 G91.1 G49
G20 (Inch)
G30
N10(Rotary Pocket2)
T9 G43 H9 M6
S8000 M3 M8
G54
G0 X-4.109 Y-1.3319
!Error: Failed to post data. See log for details.
