Electrical Cabinet Replacement Seal PCNC 1100 S3
I am looking for a replacement to the foam seal in the inside panel of the electrical control box. Any suggestions
My door seal has been looking ratty for years but I haven’t got around to replacing it yet.
I noticed some door seals once on McMaster that looked like they would be a good fit. They were extruded rubber/silicone and came in a bunch of different profiles and sizes.
Let us know if you find anything that works!
Update*
Tormach does not offer it on the website but they do stock replacement.
34634: Closed Cell Foam Rope (per ft) they said you need at least 8ft. Which is what is provided when you purchase the relocation kit.
*Note - When I installed the foam rope it sits proud and would not allow the door to close. I had to trim the foam flush with the face channel and still was a bear to close but did close.
