What is working for routing the dust collection hose on a 24R with an ATC. Does it need to be supported from up above or can you fasten it to the e-chain for the z-axis?
I have to keep the 24R setup in the showroom pretty flexible, so I usually zip tie the hose to the e-chain*. I have found that putting the vac to the right of the machine keeps the hose out of the way from the gantry moving around.
[take caution not to bind the gantry or dork up the e-chain by catching the hose on something]
If your setup is stationary then I recommend hanging the hose from a flexible pole or from the ceiling for easiest use.
That’s about what I figured . Thanks for confirming!
