Diameter wear offset not applied after resuming program via "Set start line"
PathPilot V2.12.3 on 1500MX and PCNC770.
So I use diameter wear offset quite extensively and I have in-process go/no-go checks for my production parts. There is an in-process QC op that will pause and let me check the part for tolerance before continuing with the rest of the program.
Basically when end mills have worn enough to demand a wear adjustment, I will stop the program at the QC op, add the diameter wear offset, and “Set start line (no preparation)” at the same QC op again to verify the cut is correct.
Upon resuming, the QC op will use the adjusted wear offset, but somehow all the subsequent ops using the diameter wear offset will not have any wear compensation?.
I just had to repost and rerun all the ops separately to get them to use the corrected diameter wear offset and get my parts to spec.
I am not 100% on the exact steps to reproduce this right now but it is cropping up on my production run. Previously I think it happened a few times when I was making one-offs on V2.12, but I did not catch it then.
Posting this up here to see if anyone else is experiencing the same issue?
So because of your post I am wondering if there is a way to measure tool length and use the new offset in the middle of a program.
I am working on decorating watch parts using abrasive silicon polishers and after a very short time they wear causing the effectiveness to drop off as it progresses. If I could re-measure the wear every 20 cycles that would save me a lifetime.
No tool changes just measure and use new offset and continue without stoping.
