I was facing some aluminum with a TTS 4-insert face mill on my PCNC 440 and got a nearly mirror finish with it. But, I can catch my fingernail on the edge between the passes from a step on the edge of the pass. It appears that the Z axis isn’t square to the Y axis and is leaning back a tiny bit causing the facing mill to be slightly tilted backwards. I have leveled the mill and verified it is still level. I’ve had this with another type of mill and was able to shim the Y table to correct the alignment issue, but I’m not sure what needs to be done to square them up on the 440. It does seem to be square on the Z and X axis according to my dial indicator. Is there some way to shim the Y table or adjust the Z column to fix the misalignment?
Hi Duane,
Did you find a resolution to this? I leveled my 440 after watching the commissioning series part one video for leveling and squaring. They include 440 commands in some of the information. When they get to squaring there is no shim calculation for the 440 though.
Jim
Yes and no. I got the instructions for shimming it, but I’ve just been running it with the slight tilt. The parts I’ve run haven’t really needed that level of precision yet. It’s still on my to-do list. Along with a lot of other things.
