Code question
When i go to edit the g code there is a ton of extra lines in there. Like the code is in parenthesis and then not for the actual running of the lathe. Just seems a bit much any options to get rid of it? Other than deleting it manually? If that makes sense…
Brian,
I assume you’re talking about a program made with conversational, if you delete the comments then weird things can happen if you ever try to edit the program conversationally again as the comments are how the program features are recognized. But the program will run fine with the comments deleted.
Correct. But all the gcode ive written, anything in parentheses is ignored. But its just a bit jumbled…
