I am struggling with chamfer routine in PP Conversational. IT always wants to cut Z0 TO -Z moving tool from operator in to center line which gouges into the part like this ( \ ) instead of creating a chamfer ( / on outer edge.
Does the Z EVER move spindle to positive?
I don’t remember the exact name but check the z- clearance or safe height. It should retract to that point before making any non cutting moves.
If that doesn’t make sense can you share your code or a picture of the conversational screen you have set up?
The conversational settings all look correct, what tool orientation setting are you using?
It was a issue With first tool I tried and appended the program . Forgot it kept adding the new one but the error was in the initial one I did and just kept alarming out.
