Newbie here; I’m installing an ATC on my 1100 S3 mill. Part of the install is to remove a wire from the T1 location of the Commander VFD, then plug another wire from the install kit into the same T1 slot. I removed the old T1 wire by pushing in on the tab above the hole with a small flat blade screw driver. However, when I attempted to plug the new wire into the same location, i cannot get it to go in. I’ve tried several times while pressing in on the slot above with the screw driver blade. CANNOT get it to go and I’m basically dead in the water until I make that connection.
I sure as heck don’t want to pay $575 for new VFD because I can’t a darn wire to go in.
ANY HELP would be appreciated. Even if it involves removing the front of the vfd to get to the T1 location wire plugs…
Help please…
Dave C
