I asked Tech on this, but did not get them to bite, so I’ll ask here.
This is a TAPS ONLY quesion, NO thread mills.
Im redoing my tool library and reserving tool numbers for common and standard tooling, including taps. What’s the biggest tap you’ve done on your machine? Im on a 1100M. Will it do 1/2-13 or 12-14mm?
What machine are you on? and do you think it would do a 1/2-13? in Alum? and steel?
1100mx
I use the peck taping function
Yes I think you can make it work
Use Low speed pulley
In steel do not use the standard 75% engagement increase your tap drill size ti the 60% number
Standard tap drill size for 1/2-13 (75%) is 27/64
60% is 7/16
You should be able to do 75% in Aluminum with lots of lubricant
If things start going wrong, have your finger on the stop button(not e-stop)
Hit stop, with one hand release the tool-with the other hand hit G30, then you can un-screw the tap and try again
If it’s struggling try increasing the rpm some
Good luck
Ed
