Hi all-
We’ve been getting arc ignition failures with our 1300PL; we replaced the consumables, insured the piece was properly grounded, etc. Out of sheer desperation to get the machine going I disabled Enable Arc-Ok Check on the Settings panel and magically everything started working.
Is there something on the machine itself I should be investigating as to why the arc-ok check is failing, and what exactly is its purpose insofar as with it disabled, the job ran fine.
Thanks for any info!
Ron
