Hi folks, I’ve read through some of the existing posts on the subject of moving, which have been very valuable.
Weight:
The Tormach web site says that the 1100MX machine weight fully assembled is approximately 1600lbs. Is this still accurate, or is the actual weight greater than this?
Height:
I plan to move a fully assembled 1100MX I purchased from a warehouse to my garage. My garage aperture is 82" in height ( even though my garage has 9’ ceilings and plenty of room for the machine ).
I measured the machine’s height with the Z-column lowered, and by my measurement, it appears that the very top of the Z-axis servo is about 82", plus or minus. Obviously if I use a pallet jack to lift the machine/stand it will foul the door aperture ![]()
Is temporarily removing the z-axis servo a difficult operation and/or damaging to the 1100MX?
I watched a video on youtube (https://www.youtube.com/watch?v=ZbMqXPVhAZQ). It appears that I can use 2x4’s to support the spindle flange (not the spindle nose), then remove the z-axis motor via four screws and the z-axis shaft coupler. Is this the same on the 1100MX?
