8L Fusion 360 - multi tool
I’ve created a program in Fusion that uses multiple tools - before I run the program on the 8L I set all the work offsets for each tool. When I run the program it is identifying the tool changes correctly but the offsets are not what I set. Any suggestions?
Also for a grooving tool (SGTHR-9.5-3) where do I set the Z origin - on the left, right or centre of the bit?
In the NC how are you calling the tools? If you call T0101 (for example) that will tell pathpilot that you want to use tool 01 and offset 01.
Are you using the 8l post in Fusion?
