I have a small part that needs to be held between centers & requires
multiple tools. Is there a way to temporarily change the default tool change
location ? The default location will collide with the tail stock in this case.
Thank you
Sandeep
Thank you
Sandeep
@Sandeep_Dutta I belive you are talking about g30. Typically a program will call for a g30 move before changing tools. In PathPilot there is a “Set G30” button. Simply jog your machine to a safe location and press that button.
Thank you that was it. Sorry should have done a little bit more research before posting.
Sandeep
