so …machine wont communicate with control , wont reference , move any axis or turn the spindle on . when trying to reference screen shows as axis moving till it times out . and if it helps the clunk i normally hear when pushing the green button doesn’t happen .
@peggy_chestnut welcome to Tormach forums!
To fully diagnose this issue, I would start a support ticket with the Technical Support, here: Jira Service Management
That being said I could place to start with, is opening your electrical cabinet, and seeing if the MX3660 driver is lit up.
i did open a ticket , i posted here in the hopes its a problem someone else has had and i might not have to bother the support crew any more then i have to .
i did check the fuses and my mx driver is lit up green
When this happened to me, I found the latch that closes the lid to the spindle was cracked and was not pulling the front spindle door shut. I am talking about the door you open to loosen the r8 collet. Ordered a new one and was up and running
all fixed and running again , while buying a new mx board wasn’t fun , tech support was 100% committed to getting me going again .
cant say enough good things about everyone I’ve interacted with at tormach
