We have a 24R and are having trouble with the tool height setter. After digging around a bit and checking things with a multimeter it seems that the 5 pin plug has been soldered incorrectly - is anyone willing to take the plug apart on their tool setter and post up a photo so I can reference which colour wires go to which pins?
This should answer your questions.
50388_Wiring_Diagram_Rev_A.PDF (53.2 KB)
Did resoldering work? I think I have the same issue because I couldn’t get mine to work either. I may as well try from the drawing from Davie.
And also, I did have any of the 2A VAC fuses in the panel and put those in but I will reconfigure the wiring.
