1rst Gen Turret not working with 2.12
After update to 2.12 turret moves correctly the first time TURRET FWD is clicked. Subsequent clicks cause the display to update like the turret moved, but the turret makes so sound or moves. Emergency stop and reset get one move out of the turret and then same as before. I have rolled the software back and forth just to verify. My 15l is an early model.
Andy
Thanks for the heads up. We will look into this
Any chance you pulled a log on your machine while you had 2.12.0 loaded?
Hello @ANDREW_LITTLE
My name is Rob, I work with our Tech Support Department here at Tormach. Can you please file a support ticket through our website at: Tormach Inc. - Jira Service Management
I would like to work with you directly to get this issue you are having with you lathe resolved as quickly as possible.
I will get the logs and create a ticket on the support site. I rolled back to the previous version and it works fine. Andy
Ticket created with log attached.
I also have a Gen 1 turret on my 15L and have been meaning to upgrade to a newer version of PathPilot on that. Feel free to let me know if you would like me to run any tests.
@Mike_Henry I am very curious if you have the same issue with your gen1 turret. Do you have time to update and run a test for us?
Hi @Mike_Henry, just a small update on this thread. We’re actively working on an update. If you happen to update and run into a similar issue, please go ahead and create a ticket with our Tech team. I would not, however, necessarily update to run any further tests at this time. We will post here when the update to this specific issue is ready. Thanks for all your input!
Chris/Davie - thanks for the new info. I will probably upgrade to 2.12 in the next few days and will create a ticket if that causes a problem. It sounds like it will, but I can always downgrade in that case until a fix is issued.
Reverted back to V2.10.1
Turret functioned normally.
No issues with this version noted before, IE rigid tapping, turn, face etc.
I wanted to let everyone watching this thread know that this bug has been fixed with PathPilot v2.12.2 and special thanks to @ANDREW_LITTLE for helping us beta test this update.
Anyone experiencing this issue should update to the latest version.
