15LX Lathe
Is the 15 LX compatible with Blasomill GT22 cutting fluid?
We haven’t tested this fluid in the machine and this looks pretty thick for the stock coolant pump. The coolant pump in the machine is designed for fluids with a viscosity close to water. I recommend that you source your own oil pump for fluids like this.
thanks Davie. We can source an appropriate pump. Seals,bearings etc compatible with Blasomill GT22?
